How to Copy DVDs to Hard Drive Free and Fast in 2024?
04/25/2024
If you do not have a blank DVD disc, you can copy your DVD to your computer or hard drive for backup. But how? DVDFab DVD Copy can help you copy your DVDs effortlessly and save them as DVD folders or ISO files to store them on your PC or hard drive. Now let me show you how to copy DVD to computer or hard drive with DVDFab DVD Copy.
How to Copy DVD to Computer / PC / Hard Drive: Step 1 > Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes (see Note at the end) to choose. Here I take Main Movie mode as an example.
How to Copy DVD to Computer / PC / Hard Drive: Step 2 > Load the source.
How to Copy DVD to Computer / PC / Hard Drive: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
How to Copy DVD to Computer / PC / Hard Drive: Step 4 > Navigate to the bottom of the main interface to select a directory to save the output DVD: to select a directory by clicking the "folder" icon is to save the output as a DVD folder on your hard drive or PC; to select a directory by clicking the "image" icon is to save the output as an ISO image file on your hard drive or PC.
How to Copy DVD to Computer / PC / Hard Drive: Step 5 > Click the "Start" button to start the copy process.
Note:
6 modes:
For more detailed information about DVDFab DVD Copy, please visit https://www.dvdfab.cn/dvd-copy.htm.
